another tip of the day on tires | Ford Explorer Forums
mcgyver ky
ky where all the mud is
91ford exporer eddiebauer
here is a tip i use when i am had a bad day had a flat used the spare was on way home and had another one so i found this tip very useful i keep a air line in my tube bumper and happen to have another air chuck attached it to other end of hose
put one end on a good tire with air [ chuck has a lock on it to hold it to the valve stem] and also pluged hole on flat tire then balanced the air presser between the tires by hooking them together
if needed you can do this with all three tires all i know is it kept me from walking
Robb (morriseyO) was thinking of carying a trailer spare tire underneath for just that reason...there is a thread somewhere....:D
