Anybody know the safe limits in terms of adding a load on the high beam lead? | Page 2 | Ford Explorer Forums
I want to add a 4.3 amp LED light bar and use the existing lead to the high beam side of the bulbs. Will the wiring going to the high beams handle this additional load? i dont want to run a separate wire and fuse and want to avoid doing a separate relay unless i really have to.
If you are concerned about the load, just add a relay to the high beam circuit, (minimal draw) and connect the light bar through the relay direct to a fused connection to the battery. Safest method to use.
I’m bought this for my light bar. Haven’t installed it yet though.
