Anyone ever heard of NEXEN 33x10.5x15? | Ford Explorer Forums
97SPORT_FF
DAVIE, FL
1997 EXPLORER SPORT
NEXEN 33x10.5x15
If so, this is a mudd terrain tire, will it fit with a 2" tt/shackle lift? and is this tire ok for everyday use? thanks for the help.... i'll be gettin the 3" pa lift in 2 weeks and was jus curios cuz this is the setup i wanna run..
NEXEN 33x10.5x15
Never heard of that brand. a 33x10.5 may fit with just a shackle & torsion twist but every vehicle is different. Just to be safe what I'd do is wait for the body lift before putting those tires on.
welcome
Ok, so i was wrong on these tire sizes... I thought that the 33 part of the number would mean the taller aspect. I dont really want a wide tire, i jus want to be taller up. So if thats the case, would i go with something like the 31x12.5x15? Jus confused. Pls help!
If I understand you correctly, then you were right the first time.
Tires are sized by height x width, and then rim size. For example, 33" tall by 10.5" wide and on a 15" wheel (33x10.5R15).
31x12.5x15 would be 31" tall x 12.5" wide and for a 15" wheel. So they'd be around 2" shorter and 2" wider.
I hope this helps...
I know of the Nexen tires. I've see them alot ofnwork trucks.
My wife has Nexen tires on her 03 XLT. Cheap tires that the dealer put on the truck for a saftey when we bought it. It's been 6 months and they seem ok so far. The first real snowfall will let me know for sure if they stay till they are worn or whether she's getting BFG's much sooner.
