Ross-N-Chicago
Elite Explorer<br><img src="/forums/images/stars4.
- November 13, 2001
- Chicago, IL
- '91 XLT 2wd
Ad in Poplular Mechanics Or is this just like the Tornado??
website said:Typical Installation on a '95 Porsche 928 with 5.7L engine that
is also utilizing a Nitrous system.
Actually runnign water injection in a highly modified engine isn't un-heard of. In a stock engine? No freakin' way!Charlie's_93EB said:
As this mixture goes into the combustion chamber a marvelous thing happens - a chain reaction. All carbon starts immediately being removed inside the engine to the same state it was in when it was new. This happens because hot carbon and water don’t mix, somewhat like nitro colliding with glycerine and small carbon deposits going by valve seats and helping to break off other deposits...giving a clean sweet machine with a much higher compression ratio and a more complete burning of fuels,
It’s been well known for many years, and still is today, that the steam engine is the most powerful of all engines and still used on aircraft carriers for catapulting jet fighters off the carrier. Also, the water injection was used on the P-38 fighter planes during WW II and at their high altitudes gave the engine a whopping 68% more horse power. Therefore, at 2500 feet above sea level you could expect 38% more horse power; of course, that does depend on the condition of the engine and how well it has been tuned.
More horse power and a higher torque range. This also helps keep the oil cleaner and helps to maintain oil viscocity because of the absence of bi-products of unburned fuel and carbons that can contaminate the oil.
It produces hydrogen-rich bubbles before being introduced into the engine draft.
After this it becomes an even more highly enriched hydrogen as it collides with hot metals and combustion and it drops the engine combustion temperature down. Now the engine timing can be advanced up to 7 degrees over factory specifications, if so desired.
an ultra-sonic barometric pressure chamber giving off ultra-sonic frequencies which in turn are splitting the hydrogen from the oxygen creating hydrogen-rich bubbles and hydrogen gases.
RayLCC said:oh... well... this is all testing done in lavatory conditions
Story of my life...snocross1985 said:Note to self......inflate blonde before desire will occur.....
lol
RayLCC said:oh... well... this is all testing done in lavatory conditions on highly modified '58 Edsels and nitro-powered Chevy Chevettes. Actual "seat of the pants" horsepower will drop significantly as your engine hydrolocks from having cola poured into the cylinders causing your gas to last indefinitely. The part about the under-britches... that's all true though.![]()
