Ozonkiller
- May 13, 2003
- Waddell, AZ
- '97 XLT
My '96 4WD front end has this low pitch squeak that has been getting worse over the last 10K mi. or so. I've just rolled over 100K miles. I'm assuming that it is the ball joints since Ford, in their infinite wisdom, didn't put a single zerk fitting on this whole truck,
OK, I feel better
but I don't detect any play in any of the joints. Before I replace them is there any thing else that I should check? I see nothing obvious any where else. Looking around I see Moog is the part of choice, or should I consider any of the after market "trick" parts suppliers? I use this truck mostly as a "Boulevard Cruiser" with the occasional trek up to the snow country or down that interesting looking fire road.
I will also add that I have a pretty extensive shop with machining capabilities. Once I have all of my options sorted out (parts available when I screw this up) I will see if it's possible to install Zerks. I'll keep you posted.
Thanks, Tom
Thanks, Tom
