Are the axles different between 4x4 and 4x2? | Ford Explorer Forums
maguinness
Tampa, FL
1995 Explorer Xlt
Does anybody know if the gear ratio the same or different between the 4x4 and the 2wd on a 95 explorer. thanks
The axles are the same. If you look on the drivers door jamb, you will find a sticker. On that sticker find the heading "axle", under that will be a code. The codes are below to tell you what type (open or limited slip) and ratio you have.
Explorer
Door Code
41..... Open 8.8"…...... 3.27
42..... Open 8.8".…..... 4.10
43..... Open 8.8"…...... 3.08
44..... Open 8.8"…...... 3.73
45..... Open 8.8".…..... 3.55
46..... Open 8.8".…..... 3.73
D1..... L/S 8.8".…....... 3.27
D2..... L/S 8.8".…....... 4.10
D4..... L/S 8.8".…....... 3.73
welcome
