Wanted - atf transmission dipstick seal / o ring (2 maybe) | Ford Explorer Forums
Wanted atf transmission dipstick seal / o ring (2 maybe)
Parts or services wanted
SB98UKexplorer
UK croydon
98 explorer 4.0 SOHC v6
has anyone got o rings for the dip stick tube that sits inside the transmission? need that before this weekend and loosing enough fluid as it is. cheers
Sorry dude i know the one on a spare dip tube i have is fooked as i heated it up to get the tube out of tranny.
As a short term stop gap you could wrap the area the o ring goes with ptfe tape (the white stuff plumbers use. 70p from any DIY store
Do you have a bit of the old o-ring to measure the cross section, etc?
Take the dipstick to a local engineering suppliers to select an o-ring that fits.
Measure the diameter and width of the groove and look at the following site to find a suitable o-ring:
http://budgetbearings.co.uk/shop/index.php?cPath=19_4501
GRoB
Halfords to a multi-pack of different sizes for a couple of quid, bound to find one the right size
would anyone happen to have the part number for it, gonna pester ford dealers about it, so far the genuine one from rockauto is the only source to get one for 9p plus 12 quid P+P.
Finis code: 3503897
HTH
SS
thanks ss im giving em a call tommrow
o ring
hi steve i will be dismantling a black 2000 north face next week i may be able to get the o ring out for you . cheers chris
cheers chriss, iv made a modification on the bracket holding the tube, so now the tube sits into the gearbox very tight and is working allright for now, if you do get that o ring out let me know cheers chriss
Chris. The North Face doesn't have running boards does it? GRoB.
hi rob yes it has pm me as i dont want to hijack steves post .cheers chris
