I wonder if the way the front has been lifted would make a diffrence with the tire rub, I have the james duff 2.5" stage 2 lift, but havent installed it yet, but after some thought, the front beams are pretty much a hidge, so forcing the beams down 2 inches would cause the stock backspace to be closer to the inside of the truck, and the radius arms are on the same idea also, so maybe (I could be wrong, I might test this later when I put the lift and arms on) the spacer/spring front lift is part of the problem, also it doesnt take much for something to move the outside of the tire farther in or out, 2 bad ball joints gave my front end enough play that you could see the diffrence, top of the tire would go from 1" out to 1" in, about 2 inchs of play to the top of the outside edge of the tire, may be the truck also, I had 31x10.50x15 on my truck with out anylift and they didnt rub, unless you tryed to flex the truck, no lift = no flex at all
