Auto Hubs Service | Ford Explorer Forums
Auto Hubs Service
Buckshot_1
Ontario
92 XLT was
How do you service the auto hubs. I would like to clean them up, but do you use grease
or light oil?
Also can manual hubs be used with the push -
button transfercase?
Ken P.
1992 Explorer XLT 4Dr 4x4
Kenwood sound system
K&N filter,modified airbox
thats it 4 now!!Well Maybe!!
Well, as far as servicing the hubs, all I sugest you do is repack these babies with the same grease you use to repack the bearings. I don't think these things are meant to be torn apart. Manual hubs in a push-button? Why not? Even if you push the button you still have to go around and engage the hubs manually, right?
Later,
Dead Link Removed
Andre Hryn
94 Limited
Andre's "baby"
Don't use Bearing Greese. Bearing greese is too thick and will keep the hubs from engaging/disengaging correctly. I've heard someone used ATF fluid so I gave it a try it works very well. I used ATF for almost a year before I replaced them for Manual hubs (I now carry them as spares).
Mark
mark@legendz.com
http://mark.legendz.com
Off-Road and Motorcycle Information, Pictures and Movies
Click Dead Link Removed to see our Explorer Specs
ATF? but wouldn't this mix with the bearing grease and dilute it? Are we talking about the same thing?
Dead Link Removed
Andre Hryn
94 Limited
Andre's "baby"
Andre,
What you are doing is coating the hub parts with ATF fluid, not packing them or drenching them. It won't hurt the the seals because you are not using much ATF fluid. A little bit goes a long way. Dead Link Removed
Happy Wheelin'
Ray L.
97 XLT 4X4 4.0L SOHC
Dead Link Removed
So then it's ok to use a cleaner to clean out
the auto hubs with varsol? Then just put some
ATF in the hubs and if too much just dump out. Dead Link Removed
Ken,
Mke sure you take the auto hubs off before cleaning and relubing, then put them back on.
Happy Wheelin'
Ray L.
Dead Link Removed
Thanks for your help guys!!!!!
Ken P.
