Auto vs. Manual Hubs??? | Ford Explorer Forums
gmycyk
belleville, nj
94X, 94Sport, 91EB, 92X
What, if any, is the advantage of replacing the stock automatic hubs with manual hubs?
the manual hubs are a lot stronger, cheaper, and more reliable thn automatic hubs. I switched to warn manual hubs and it is well worth the money.
I did the same thing, go with WARN manual hubs. The automatic ones wear out way to quickly. It's a pain to get out and engage them, but it'll save you money.
What about 2 gen X's? Is it recommended to switch those out as well? I have a '96.
you cant.. .you dont have conventioal hubs....
I've also noticed an increase in gas mileage with the manual hubs.
Could you explain more? Do you drive in 4wd that often?
Couple questions... I assume the dash switch is still needed after switching to manual hubs... gotta switch between hi and lo, right? So if the hubs are locked and the 4x4 is off the hubs will stay engaged, but there won't be power going to them? Is it possible to install a regular shifter to shift beween rwd, 4hi, and 4lo?
if the hubs are locked then the axle is moving but if 4x4 isn't locked in then it isn't in 4x4, the front shafts are just locked in for no reason, your not suppose to keep them locked in all the time if you don't use 4-wheel drive often
yes it is possible to install a floor shift instead of the push-button switch
In addition to what was said above, I might add that auto hubs require a hard-to-find specialized hub socket (about $25) to work on the bearings and/or rotor. Manual hubs only need a tine spanner socket which is easily available at any decent auto parts store for about $10.
I can see that happening...IF the auto hub adjusting nut was torqued too tightly. Then the wheel wouldn't be able to turn freely and this rolling resistance could conceivably hurt mileage.
