spta97
- June 12, 2003
- NY, NY
- 2000 5.0 AWD
Back in July I got a set of Autozone rotors and Morse ceramic pads for my 2000 V8 AWD. They were fine for the first 1000 miles and then developed a squeaking sound at the end of the brake cycle (right before you come to a stop). I swapped them out with new rotors and pads (of the same brands) and I noticed that the sqeaking only happens when they get hot. On the few days where the temp has been around 60 they are quite, but after a while the squeak returns. On hot days, it happens after a few presses of the pedal.
I have everything torqued to spec (according to my Haynes manual) and have used disc brake quite (spray) on both the pads and shims along with generous amounts of caliper grease on the backs of the pads, contacts on the caliper, pistons, and bolts and still the sqeak remains. Does anyone have an idea what could be causing it? The sound drives me nuts expecially since I've had the wheels off and on more times that I've filled up in the past few months.
The only part of the installation that I'm not sure about was if I was supposed to spray the back of the pad with disc brake quite then apply the self adheasive shim or if I should have not sprayed the back of the pad then applied the shim (it seemed to have moved slightly on the first set of pads on one side).
Can anyone help me? I'm going NUTS with this sqeaking and it is making me not want to use my brakes!
