jthmartin
- October 4, 2003
- Peoria, IL
- '98 XLT
I have a problem with my driver door unlock/lock function. It does not work from the driver door switch. I have a keypad and remote both of which are working fine and unlocking/locking all the doors. So, I thought it must be the switch. I replaced the drivers switch and the problem still exists. I think it must be a wiring issue. The drivers door unlock relay is working since I switched it with the horn relay which worked after the change. Has anyone else had this problem? (I'm assuming the new switch from Ford is not faulty-maybe that's a poor assumption since I really find it hard to believe that its a wire/terminal failure).
