Auxillay/climate control occasionally out? | Ford Explorer Forums
shane10
MW
2002 Explorer XLS
4WD
Hi all, i've had this problem for a while now but never really paid it much attention.
Occasionally, my climate control panel (air setting, temp, and direction) will dim, but only on half, sometimes it's the left sometimes it's the right. I know it is lit by two backlights, one on both sides.
I thought about changing the bulbs, but clearly they aren't burnt out or it wouldn't turn on at all.
Is this most likely a wiring problem? fuse? i'm really at a loss for what the cause could be.
If anyone has had this problem and has any tips it would be much appreciated.
02' explorer XLS if that makes any difference.
Thanks!
Forgot to mention, sometimes the whole back will be lit up, others completely out and dark.
Same problem with odometer, thanks.
