invecta18
- January 26, 2014
- Clearwater, Florida
- 2000 Mercury Mountaineer
I recently join this Forum as I recently bought a 2000 Mercury Mountaineer. It has become very apparent that the 2000 Mountaineer is basically the 2000 Explorer and that all the tech information and tips . etc are best found and answered with those who have an Explorer. I unfortunately have the AWD. Perhaps , the stupidest, least convenient. poorest thought out inovation ever installed on a car. It is difficult to try to understand why Ford would do something so stupid as to make a 4 wheel drive vehicle that doesn't allow you the option to switch it to 2WD. It is baffling to me as this AWD configuration makes the car handle like a tank, add perhaps 800 - 1000 lbs of unnecessary weight to the vehicle, it reduces the gas mileage by at least 2 to 3 mph, and puts constant wear and tear on a front differential and transfer case, and insures costly repair and maintenance well above the conventional 2wd. A feature that even in a snowy climate would be needed less that 20% of the time. A lose - lose - lose - lose concept. And this all could have been fixed with a 2wd- 4 wd transfer case, or at least helped.
I have read , or tried to read some of the threads posted. It is a little difficult. I am wondering if I can start by asking if someone knows the model number or type of transfer case that I could swap with the current AWD unit I have. I have the 5.0 v8. I did read that someone was going to manual shift, I am not interested in that , I wish to do whatever I can to get rid of the AWD system and I believe the 4wd-2wd transfer case swap ( if possible) would work. I would greatly appreciate any help
