Changing the rear-end fluid is pretty straight forward.
You are going to need.
- A 10mm socket (I think its 10mm)
- A big, short bucket to drain the oil into or a plastic bag with some duct tape (will explain later)
- 3 quarts of 80w-90 gear oil (cheap stuff) or if you have a factory limited slip, or you want to just go with a better oil (better usually means better miles per gallon also) 70w-90 synthetic gear oil (Amsoil is a popular brand)
- 3/8 drive socket extension (for fill plug on the front of the differential housing, directly left of the pinion/driveshaft)
- A new Gasket... Felpro makes a pre-made cork gasket available at most auto parts stores... for cheap.
- Some RTV (I like RED, but a lot of people use BLACK for this kind of stuff)
- A razor blade
What you need to do
1) Put the pan underneath the differential cover. Or here this is where your plastic bag comes in handy. Use the duct tape to tape the corners of the bag to the front of the differential, and stretch it around front and tape other side of the bag to the sway bar. Works pretty good.
2) Unbolt the 10 cover bolts from differential. Once you get them all out you are going to probably have to pry at it to get it loose, but once it does... OIL IS GOING EVERYWHERE!! Haha this is where the bag comes in handy.
3) Now get out a razor blade. You got to scrape off all of the old gasket/silicone from around where cover was. Make sure its basically bare metal before you call it done, failing to get the entire old gasket off will cause leaks later.
4) make sure to scrape all the old crap off the edges of the differential cover too! BARE!
5) Go around the middle of the gasket with RTV. You want to make a complete trip with the RTV around the gasket, on BOTH sides (might not be necessary, but I do it, more the better) Smoosh the gasket onto the cover...
6) Smoosh the cover+gasketw/tons of RTV onto the differential.
7) Torque down all the cover bolts to 35ftlbs (I think?)
8) Then go around back, with you 3/8 drive ratchet and extension, and you will see a little fill plug. It will be on the right side of the pinion (from looking at it head on). The end of the extension should fit right into the female part of the little fill plug. Once you get the plug out, proceed to fill the differential with 2.5 quarts of gear oil. You are probably going to need a funnel that has a hose attached to it
9) Reinstall the fill plug/magnet and you’re DONE! It should be good to go unless I forgot something...
Dont worry about the Aenema... it wont hurt
