Thank yall for the reply, I guess I'll go to ford and see what they pull up. That way I'll know for sure. What type of 2 doors were they koda2000? I have that death wobble going on and I'm almost sure that damper is why.
I am puzzled - what are those big round things on the bracket by the axle? Mine doesn't have it - see below.
If it is any comfort, I have been using the Monroe HARD for over a year now, no problems so far.
I guess that is another vibration damper that was installed only for certain pinion rations (higher ones, especially the 4.10 one) that might have driveshaft vibration resonance modes at certain speeds:I am puzzled - what are those big round things on the bracket by the axle? Mine doesn't have it - see below.
I doubt a bad (or missing) rear axle damper would cause a "death wobble". That sounds more like some other suspension problem (rear or front).
Whether or not the 2 door Ex's have/had the lower axle damper mount on the axle, they wont have the upper mount on the frame.
Junk yard? But you will need a welder to get the one on the frame.Anyone know where I can get these mounts from?
I might just install one and see what happens. Anyone know where I can get these mounts from?
Look into a Watt's Link or Watt's Linkage.
They perform a similar task but would work much more effectively.
A Watts link controls lateral movement of the axle with out it traveling in an arc like it would with a panhard or trac bar. The 5th shock controls axle wrap.
I'm gonna pass by the ford stealership tmro and let y'all know what info I find out. Might see how much the mounts are too.
Its about the only thing I can think of causing the death wobble. I done went through the entire vehicle. Can't find anything else that would be causing it.
