B&M shift kit C4 | Ford Explorer Forums
B&M shift kit C4
rookieshooter
Moderator Emeritus
Elite In Memoriam
Martinsburg WV
84 BII "Li'l Samson"
Had to get another C4 for my B11 build. The first one had rust all thru it. I just picked up another one last night. This one is sweet. My question for the auto tranny gurus is this. It has just been rebuilt and has a B&M shift kit in it. It was in one of his drag cars. The guy I got it from says I should take it out for street. That it would shift too hard. What's your thoughts. I have to take it to the tranny man to put the C5 output shaft and tail shaft in and he'll check it all out. Should I tell him to take it out and install a stock one? I thought that harder shifting ones was less strain on the clutches because they did not slip as much creating less heat. Then again I don't want this to slid all over the road during wet conditions when it shifts.
The B&M kits can usually be adjusted from mild-medium-max by enlarging the plate holes for fluid passage (last one I had included the drill bit in the kit.) If I were in your shoes, I would install another new shift kit but at a mild or moderate setting. Going back to stock would be disappointing. The advantage of a mechanical shift kit is noticable and well appreciated; I still use mechanical kits along with upgraded tuning.
Greatly appreciated :thumbsup: I"ll tell the tran man what you said. I'll be taking it down to his shop this week.
