Anyone know of a camera i can hook to my alpine tv (in the console) so i can see where i'm going in reverse. My windows are tinted and i can't see a thing at night when i back up. I do not want a whole camera system, just the camera. Any help is appreciated.
i think a member named "big mellon" or something like that has a reverse camera on his sport trac. he removed his rearview mirror and has a screen there instead and he uses the camera on that screen.
how dark are your windows tinted, because mine have 10% tint and the 20% factory tint, so its like 5% between the two and i just put some xenon reverse lights in and i can see behind me at night now. this may not be what you want, but theyre only like $15
At night my windows might as well be painted black.
The xenon lights are a good idea, but does the wattage amount match the factory. Those aftermarket bulbs are known for melting factory switches. I do know from exprerience.
I have seen it somewhere a rearview mirror camera combo. The video screen is in the mirrors left corner. The camera is also very neat and can be mounted to the license plate.
Garth,
That license plate camera idea sounds the best, only thing is i need to use my existing alpine tv that is mounted in the console. My mirror can't go since it turns my headlights on and off.
I had the idea of tearing apart an old digital camera and wiring the lens in the rear somewhere, and the little monitor in the dash somewhere. Just never got around to it and now I have no idea where the camera is.
Originally posted by tbomb i think a member named "big mellon" or something like that has a reverse camera on his sport trac. he removed his rearview mirror and has a screen there instead and he uses the camera on that screen.
They also sell just a camera to use with an existing video setup
Dead Link Removed - $249.00
Features:
High resolution, 1/3" CCD camera
Compact / lightweight aluminum die cast body
Waterproof housing
Waterproof Microphone
Waterproof Normal / Mirror image switch
Adjustable viewing angle
Infra-red LED assisted low light performance enhancement
Wide Angle Lens
Optional Air Deflector
For use with rear observation systems such as:
VEC-65 Cable
LCM640CS 6.4 LCD Screen or most any color monitor when used in conjunction with 8000550 camera cable adapter.
