JimMadsen
- April 1, 2012
- Stafford Springs, CT
- 2017 Ford Explorer XLT
Yesterday noted that the battery needle was very low. Plugged in my cig lighter volt meter and was jumping between 11.3 volts and 13.4 volts. Quickly got home and hooked up the trickle charge for about 12 hours. Volts while off is 12.2.
Popped the hood and saw that the belt was shiny. No frays or cracks, just that glazed look. Replaced that this morning and volt meter at the dash while running is 11.4 volts. I should have 14+ if alternator is working fine.
So.... Time for a new alternator?
Also, I removed fan and shroud and saw that the 11 blade fan is pretty cracked. Still in one piece, but.....
I find new ones on eBay in plastic. Those are 12 blade for the 4.0, then there are used 9 blade metal ones that are 5.0 pulls. Does it matter?
