Bad radiator leak! | Ford Explorer Forums
Bad radiator leak!
slyfoxexplore
cheyenne wy
1996 xlt 5.0 awd
Well i was towing the explorer from pennsylvania to wyoming when i noticed i had a horrible leak of radiator fluid. I was under it for hours and cant seem to locate it. what the best way to find and it and fix it.
maybe a timing cover gasket? thats whats wrong with mine and i couldnt find it at all but it only took my mechanic 5 minutes lol
tha sux ur radiator is leaking
is this something that happens alot to the 5.0
idk if it happens alot, my mechanic said i probably just knocked it loose when i replaced my water pump.
I had a bad leak and couldn't track where it was coming from. I pulled the radiator out and there was a crack somewhere on the front (side facing the grill) that was leaking and moving down the plastic fins on passenger side. I sealed the inlets/outlets on the radiator and filled with water and saw where the leak came from. Oh yeah and removing radiator on the 5.0 is a pain in the ass lol, even had to file the new one on it's clips so it would fit and not bind.
Pressure test it. If you can't see the leak, hopefully you'll be able to hear it.
