Battery issue. | Ford Explorer Forums
Battery issue.
habanjar
04 XLT
hi every one
i have explorer 2004 XLT
my problem that always battery die
i check the dynamo it's ok
i check the battery also good
the doors light will be off after maybe 5 min
the battery die when i open the doors and don't lock them again
or if i keep door open
can any one help me about that plz !!!!!!!
any help here plz
checked all fuse and they are all good
i need help plz
do i have to change battery ??? or not ??
Have you done a load test on the battery? I know you said it's "good" but a load test will uncover problems that simple volt meter will not.
How long does it take for the battery to drain down to the point where it will not start the vehicle?
hi
i make load test and it's good i make the load test for 10 sec
if i unlock the doors for long time, it will do that.
if i open and lock in less then 2 min it will work normal and vehicle can start normal
but if i keep the doors unlock the light will be off and no more power
and about the starting at morning or any time it will work in sec's it will work normal
i get my multi meter and measure the current when the car is off it give 0.83 A and the current it's for fuse No 15 Memory (PCM/DEATC/Cluster),
Courtesy lamps if i remove it it will read 0 A
thx if u will help me about that
hi if any one can read this
i found near the fuse panel under the passenger white box with screw when i touch that box the a relay give sound and all the meters began to move up and down + sound of relay
i tie the screw and then open the doors and wait until the lights get off then try to run the explorer and it work normal, not as be4
so i think the problem solve but need to know what was the problem ???
i need ur help plz
hi every one
before i ask here about a problem in my battery
that some time battery die without any alarm and some time even i open all the doors it will stay normal
then i found a white box with screw near the fuse panel
when try to touch the screw some relay began to give sound and clusters speed meters began to go up and down
i tied that screw and the relay stop and clusters stop to there normal position
i need to know what is that box and can i open and use counted clear inside ??
ok thx a lot
but until now no one told me about that box what is it ??
