Dennis94XLT
- October 11, 2002
- San Diego, California
- 2005 XLT
I obviously have a 94 Explorer XLT and a problem with it.
Believe it or not - it has the original factory battery and up to 3 months ago, the truck has had no problems with starting. At first, I noticed it would start real hard (almost like it had water in a cylinder) after sitting about 5 minutes after stopping the engine - but did always start. It does not loose coolant and no steam is coming out of the tailpipe (mileage is 79k)
Two weeks ago, it started fine in the morning and I went to work, I came home, stopped the engine long enough to unlock the gate, and the engine cranked like the battery was almost dead - then the solenoid clicked. I found what appears to be corrosion on the negative terminal - so I took it apart and cleaned it up and put it back. I still noticed the slow starting when the engine has just been shut off and is being restarted and today it would not start again at my driveway entrance.
I've checked all the connections and all is tight. If the battery was bad, I would expect it to have trouble starting after sitting overnight - not the opposite. I wonder if the starter is having a problem with engine heat.
Does anyone have any experience with something like this?
