jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
Haha o well we also found that the pinion got chewed up so im buying a new axle tomorrow got one for $250 lined up just going to replace the whole deal instead of buying pieces. Do you know if I can just buy 4.56 gears for the rear and not the front and get by? Or would that screw everything up? I am running 33's on stock gears which I'm assuming is why they broke. But I dont want to spend the money on the front because I want to sas soon. And I dont wheel enough right now to be using 4wd.
Just take the axles and driveshaft out/off.then rebuild it whenever you get new gears, save your $250...yes you can run just rear 4.56 but you wont have 4x4 and again you should take the driveshaft off just in case
