before I order want to double check | Ford Explorer Forums
chrisw2012
tn
2003 sports trac
So im fixing to order new bulbs to put in so four map ligjts ( the little ligjts you turn on over your head by the lil blsck switch in front and in the back. I thought it was a 194 or something like that bulb but when re checking myself before ordering I started seeing all sorts if differant #'s people are saying they are so be for I throw a couple dollsrs out the window which exact bulb # do I need
I would pull an old bulb and look at the bulb it will have it's number printed on it usually on the metal base or on the glass bulb itself. replace with the same.
Alright someone has replaced it with a blue bulb and im wanting go replace it with a green led bulb trting to stick with a plug and play but I didnt knoe they had them printed on them thanks for the info.
