best settings for pioneer amp and headunit | Ford Explorer Forums
jd92887
Omaha, NE
2004 XLT - 1993 XLT
i have a 760 watt amp model number gm 5300t
a headunit model number deh 12e
and 2 Visonik 12s
can i get help to set these up for the best bass thank you
gonna be very hard to give advice on electronics we dont 'have access to online.
To set the gain properly though, you need an Oscilloscope so you can see the curves and makes sure the signal the amplifier is putting out isn't clipped and is CLEAN. Everything else coems with practice. See video for setting gains:
http://www.youtube.com/watch?v=xSUuBBJQ4Wk
no offense you are running one of the most cheap/basic pioneers out there. there really isnt too many adjustments that you will be able to make outside of the bass and trebble.
on a side note if you look at the specs of that amp its really only 380 watts bridged into 4ohms
If your subs are 4ohm speakers you cant bridge it because the inpedence level at the amp will be too low and it will cause it to clip out. If they are 8ohm subs then you are ok. If 4 you are going to have to run it in stereo mode and then they are only getting about 125 rms watts.
With your equipment just adjust it until it sounds good to you.
