Big hp out of a 4.0l ohv | Ford Explorer Forums
quickerest
California/Canada
92 EB/ Bush buggy project
I could not find the answer right away so i figured this might be helpful for others. When you look at swapping a v8 you might want to consider this instead.
"We offer ported cylinder heads, cams, forged pistons to raise the compression ratio. To make 400 HP you will also need a 125-shot of nitrous or a turbo system."
"Stage 3 cylinder heads: $1750 http://www.supersixmotorsports.com/pdf/SSM2009catrev1CylinderHeads.pdf
Ported lower intake: $350 http://www.supersixmotorsports.com/pdf/SSM2007catrev3IntakeManifolds.pdf
Forged pistons: $805 http://www.supersixmotorsports.com/pdf/SSM2009catrev1ForgedInternals.pdf
Adding forged pistons to be used with the stock forged rods will let you run a 100-125 shot. With the forged pistons, and head choice, you can effectively run compression ratios from 8.5:1 to 12:1."
Tom Yentzer
478-256-7766
