Big tires with lift? | Ford Explorer Forums
likibow
ST Limited V8 2007
hey guys i'm about to change tires and wanted to know what is the biggest tire size i can fit on with truxx lift i have 20" wheels with street tire now i want mud tires, thanks!
265/65r18 is all I could fit on stock rims. If your offset is the same as stock I wouldn't go any wider because you'll rub the suspension. Get on a tire size comparison for you 20" rims and you should be able find a close tire.
