You would need to look into their extended upper control arms so you don't max out your ball joint. You would be able to run 265/75's, some people have stuffed 285's with some trimming. With the loss in fuel mileage, I would't recommend going bigger than 265's.
Any lift over 1.5" should really use the control arms. If you do a 3" and 2.5" lift without them the ball joints WILL rip out on you when you are driving.
