Rocketheavy
- April 17, 2004
- Bozrah, CT
- 98 XLT 4x4
So my blend door is screwed just like everyone elses. I either get all hot or all cold and sometime i cant get any heat at all until now. I have stumbled apon the fact that if you take the white actuator box out completely, you can then change the blend door from cold to hot by simply going about ten miles an hour and stomping the brakes for a second. This forced the door to open to the heat setting. You can actually here it open when you do this. The only strange thing is when you shut the truck off and turn it back on the blend door seems to go back to the cold setting so you just need to tap the brakes again. I have been doing it all week with great success. I tried the blend door mod on here but no luck. so in the mean time, this works perfectly. i hope this helps out alot of people because its getting really cold here in CT. Please let me know if this helps anyone at all or im just getting lucky!
