How to: 2nd Gen Blend Door Quick Fix | Page 18 | Ford Explorer Forums
Fixed Blend Door Problem!
Chiming in here with some tips following my adventure fixing the blend door actuator. I have a 2000 Mountaineer with Automatic AC (EATC - basically you set a thermostat type temperature). What follows are an immediate work around, and permanent fix.
Quick Manual work around. This is a fairly quick job (less than an hour) that will get you working heat and AC up and running. My blend door was OK (sometimes the hinges crack apart) but my actuator (the motor that moves the blend door) failed. If you don't have a replacement actuator, you can still get things working. After searching the web I found an explorer forum that showed how to access the blend door by cutting into the black plastic duct work in the passenger foot area. . . .not as bad as you'd think . . . Check it out for details and pictures but here's the summary of my experience. Looking under the dash on the passenger side (head on the floor . . not comfortable) you can see black duct work. About the area above where your passenger's left foot would be is a fairly flat are of the duct. Look for a raised round area (a bit smaller than a dime but about a 1/4 inch tall). This is where the blend door pivots. Using a cheap rotary tool with a cut off blade I cut out a couple-inch or so triangular area beside (but NOT including) the hinge's raised area. The area I cut out was within the small flat area beside the door hinge. Once open, I could touch the blend door, moving it one way or the other with my fingers (after the actuator was removed). During the summer I wedged it in the cooling position, and vice versa in the winter. You'll need to close the hole up for the air to pass through your ducts instead of the new opening. Using one of those black plastic covers for an electric box, I fashioned a door (cutting it with the rotary tool, about a 1/4 inch larger than the whole I made), added some weather seal and screwed it into place. The fix can't been seen since it under the dash . . . unless you put your head on the floor. I lived with this solution through two years of procrastination/searching for the right actuator.
Permanent fix. The blend door for automatic systems are different from the manual systems. They look similar or even identical on the outside but internally have a different circuit boards. Also, the automatic Actuators I found on line and at auto parts stores did not work on my older system (2000) so I found one as a junk yard. (On further thought they might have worked but at the time I didn't know about the EATC reset procedure described below . . .crap!). The Blend door actuator is a pain to get out. The back screw requires a lot of patience but completely doable. I didn't bother to put the back screw back on for my replacement. Aligning the post that sticks out of the actuator (about an inch) with the blend door hinge is a bit tough too. 2 things seem to be required. 1. The actuator needs to be near horizontal (not tilted) position. What worked for me was I put in the front left screw a couple turns and then stuck a screw drive under the left side of the actuator to prop it up. 2. The post that sticks out of the actuator needs to be aligned with the hold in the blend door hinge as is has a unique shape (round on one end, flat on three sides). With the access door open (see my work around in the paragraph above), I could move the door around until the actuator dropped into place. Once in, I replaced only the front two screws and it works fine. If you don't do the access door to help with alignment, you can use a cell phone to take an image of the opening to see its position, then using your ac controls, move the post into the proper position (basically get it to move by plugging in the wire harness to the new actuator, switching your ac controls between ac and heat and then pull the plug on the actuator when the post reaches the correct position. If it doesn't move, use the procedure in the next paragraph to reset your EATC system. If it doesn't move after resetting, you either have the wrong actuator (a good possibility) or something else is wrong, such as a fuse or ac control panel problem.
Resetting EATC. If you have an automatic temperate control (EATC), not the manual system, you will likely need to run a diagnostic test and then clear the fault code(s) on your temperature control system. (EATC systems have a digital display of temperature settings and several buttons while Manual systems have just knobs, I think). With Car power ON and AC OFF, press Off and Floor (at the same time) and then press Automatic within 2 seconds. It will take a couple minutes to run the test. When done it will display any fault codes. To clear codes and reset the system, press Def (defrost) after the diagnostics has run. Good Luck!
I have a Dorman #604-202 Blend Door Actuator and a Dorman #902-221 Blend Door brand new still in the box. Non-EATC for manual controls. Turned out I did not need it for my '98 SOHC. If anyone is interested, pm me and make an offer. I'm sure we can work something out.
blend door
I followed the quick fix instructions. once I had my hand inside the door wouldn't swing closed for heat. there was resistance that kept pulling it back. so I was unable to pull he door toward me to gain heat. What Now? Any suggestions?
I'm having a problem with resistance pulling the blend door open so it sits half way between hot and cold. Is there an easy method of disabling the AC during the winter so its not mixing with the heat?
I thought about wedging the door closed but haven't figured out a way to do that with the small space I've cut open.
Hi y'all. Just bought a 96 Explorer Sport and noticed no heat, looked online and stumbled across this. Sure enough, that seems to have been the problem. Already had holes cut and I cannot find the door AND the actuator is missing. I assume I at least need that door to put in a certain position to get the heat? Any and all help will be appreciated. Thank You
Just went through the chaos of replacing the actuator and wanted to share my experience. First off the NAPA replacement wasn't good out of the box, simply defective. The second unit, a Dorman worked just fine but I couldn't get the square drive into the blend door receptacle. After several tries I measured the drive and it was 30 thousandths off in both directions, touched it up with a sander and it dropped in no problem. Take aways;
Don't try and undo the 3 screws it's a waste of effort. The actuator is designed to snap on and off the frame. If you look at a pic you can see that the actuator can be pried straight up, leaving the frame intact and the just pressed down back into place with a positive "snap"
Be sure and orien the the blend door and the actuator since one side of the drive mechanism is radiused (it only goes one way) a 1/4 ratchet extension fits perfectly in the blend door receptacle which allows you to orient and test the blend door movement while the actuator is out.
Hope this helps someone, if I had a working part and this knowledge it would have been a 10 minute job.
can this be done on a 97 mountaineer as well? ive been driving around without ac due to the blend door for about 3 years. should I need to do something to the ac before I try to run it again?
This is a great repair site but I think this might be my last post. I have a new blend door repair kit that I won't be using. My wife moved to an Expedition. I will send it to someone if you don't mind the wait. I'm in Canada so I don't know if it will be advantageous to send it or not. Let me know.
SEND ME A PRIVATE MESSAGE IF YOU WANT IT.
I think the Mountaineer is identical. i ended up cutting into bottom of air box and removing blend door, replacing with Doorman part, repaired hole in air box with epoxy.
Make sure door is broken and it's not just your actuator first!
Be careful and only cut where directed so you don't damage anything else. I think there is a great step by step on this forum (could be YouTube) where a fellow shows you how on an air box from a junk yard. Good luck
The Dorman repair kit comes with a diagram of cut lines on the bottom of the plenum. Their suggested method is a round tip soldering iron. They also include some aluminized tape to re-seal the box. Again, I also have a kit I did not use if anyone is interested.
Dorman makes a replacement blend door ($10). Just remove the evaporator housing in the engine compartment and pull the old blenddoor out and put the new and improved one in. Takes about 2 hours if you take your time.
Hey Rick I like your idea Is there anymore it or is it right in the open
It's right in the opening where the Evap is located on the engine side. You will see it when you pull the evaporator out. Just lift up on the broken blend door and pull it out. Installation is in reverse.
I did this many years ago and I had to take a very small diagonal portion off the door (one corner). There was no way it would fit otherwise. It does not affect functionality and it has been working fine for like 8 or 9 years!
Thank you so much I have had no problems with my explorer until this my wife told me to fix it cheap and that should work
I have a question about this before I start hacking up the duct work. I have a 98 EB with the EATC and it works great on AC, will move from floor to vent to defrost no problem but it will not put out heat. I ran the diagnostic and got code 024 and 025 so from reading what I did I still am not sure if it is the blend door or an actuator. Any help would be appreciated! I did try to clear the codes and checked the fuses but codes still there and the fuses are good. So how do I find out if it is an actuator, motor , something else electrical or the blend door itself?
If you drop the glovebox down and look at the top of the heat box u will see the actuator mine just pops out but I was able to get it out and see if the gear was moving
Hey Rick you are a genius That was easier Than pie thanks for the advice
for those of you who like me, dont want to shell out 1200$ to fix this blend door issue, you can do this. im writing it in as simple a way as i can for those, who like me, arent very mechanically inclined.
open glove box, and push the sides in to drop the box down as far as possible. you will see a big black plastic box. inside of that box is the blend door, and your heater core (looks like a miniture radiator).
take a razor knife and on the farthest left side of that box, cut a square hole big enough to get your hand in (only cut 3 sides of the square though so that you can just bend the plastic down out of your way and put it back in place when finished). now that it's open, you can see the heater core, but not the blend door. the blend door is located around the back left side of the heater core. reach your right hand in, with your thumb down, so the palm of your hand is facing the passenger side of the truck. when you reach behind the heater core, you will feel the blend door, and you can swing it open or closed. if you want your air conditioning to work, open the door all the way. if you want your heat to work, close the door all the way. after you have adjusted the door how you want it, blend the plastic you cut to get your hand in, back to it's normal position and tape it up with some duct or thick masking tape.
unfortunatley you can only have hot or cold doing it this way, but it saves you 1200$ and a lot of headaches trying to fix this by pulling the dash.
for where i live, i need only a.c. in the summer, and only heat in the winter, so i just go in and change the door position twice a year. the original job takes about 5 minutes, then at the beginning of summer or winter when i go in to change the door position, it takes me about 3 minutes, and most of that time is spent removing the tape and retaping it.
i hope this helps someone.
Hey hi
Ummmmm I did the same thing that you did by Cutting a Hole in the big black plastic box in my glove box and then i put my arm inside and could feel a door but when i tried to open it or move it, It wouldnt move or do anything so am i doing something wrong?
I have a 1999 Ford Explorer Eddie Bauer Edition 4.0 4wd suv any help from you or anyone be nice thank you and everyone..
Hey hi
Came on here to say the same thing. I'm in the process of checking out the actuator to see if it needs to be replaced, but that third bolt is such a ***** that I'm trying to do the quick fix of moving the blend door manually to have some heat in the meantime. But in every video and explanation, the door moves easily whether it's broken or not. So what's the deal with it being impossible to open or close without breaking it?
I have a 98 Sport SOHC, want me to send a pm? I have air on Max AC but heat in every other mode, so I guess my blend door is shot, correct? And no, I have the three dials, no thermostat here. (except for the one that shows outside temp)
