bliestien 1" raised coils +add a leaf | Ford Explorer Forums
D
Olympia Washington
2000 ranger XLT off road
Anyone tried one inch raised coils particulary bliestiens? do you need an allignment after instalation? How does adda leaf affect ride? How ablut using coil spring spacers?
eh
Bilstein makes shocks...performance products makes the 1" coils and suggests using the bilstein shocks with them.
You will probably need an alignment after installing these.
An add-a-leaf usually makes the ride stiffer in the rear.
F-150 or custom coil spring spacers can give a similar effect to the 1" coils at a fraction of the cost.
A recognized good cheap lift is using the coil spring spacers for the front (under $30-40 for everything) and a procomp add-a-leaf in the rear ($26.99)
