blinker on when brakes applied | Ford Explorer Forums
s2shouse
'95 EB Explorer
Anyone know what could be causing my right side front and back blinker lights to come on when I apply my brakes? I also noticed that if my cruise control is on, turning on the right blinker will shut it off. It just started today with alot of rain. I'm thinking moisture has gotten somewhere it shouldn't have.
The problem is going to be in the turn signal switch itself. It is possible the high amount of moisture in the air is responsible for the problems, but that doesn't mean there isn't a problem lying deeper within. It sounds like your turn signal switch is going bad and will more than likely need replacement soon.
