Blower not working on speed 3 | Ford Explorer Forums
Killermike771
Glen Ellyn, IL
2010 Explorer Limited
The blower doesnt work on speed 3, it blows out at speed two when its set on 3. All of the other speeds work, I replaced the blower motor resistor and nothing has changed. Anyone have an idea what it might be?
replace the turn dial the control knob goes into on the climate control panel.
I had that issue on my 04. Worked on 3 and 4 nothing else.
pretty easy, pop off the dash bezel, remove 2 bolts that hold the climate control panel on , disconnect the connection and pop out the old dail and put in the new one
Welcome aboard! :salute:
I concur with jakedrew. My number 3 speed was not working and on his advice I changed the speed control knob and now all is well! I got the radio bezel with all controls attached on eBay for $14 shipped. Search around for a good bargain: eBay, Craigslist, Junk yard.
Good Luck! ;)
Are you guys referring to the blower motor control switch. I really appreciate all of the help. I am finding myself on the forum nearly everyday :)
This is what we are referring to:
picture.php
Thanks :) I will let you know how it works out
No problem. Good luck with the fix.
Thanks for the help, i changed the switch and all speeds work again. Best part is that it only cost me 20 bucks and took 10 minutes to install
Good deal! Thanks for the update!
