JasonJ92
- January 25, 2014
- 1994 Ford Explorer
Two days ago I bought a 1994 Ford Explorer Limited, 4WD 4.0L V6. I'm noticing a couple of things that make me a little nervous.
First, of course, the check engine light. It pulled code 551, IAC Circuit Failure.
I'm not sure what that is, does, or how to fix it. I'm not too bad at fixing things once I know what I'm fixing, but with this I'm kind of lost. I don't know what to look for or what to buy.
Second, it has a bit of ticking while it idles, and a knock when it starts. With the knock, it's literally as if it knocks twice as it's turning over. Every time. Two knocks right as it turns over. I'm not sure if that's something troublesome or just something it does. I've never had a Ford and I don't know how they work.
Third, the interior lights won't turn off. They turn off about an hour after I turn the car off/lock it. About an hour later I'll look outside or get in and realize the lights were off, then when I start it, the lights come back on and remain on for the entire time I'm driving and about an hour after I stop. I tried spraying the door latches with WD40 like I read on a few sites, but that didn't seem to help.
Any insight on any of these issues would be greatly appreciated
-JJ
Also, if there are any suggestions of things I should replace or other general maintenance to start off with (oil change, changing spark plugs, etc) I'd greatly appreciate that too. I'd like to get it in good running condition so I don't have to worry about it randomly breaking down on me for something I could've easily prevented in maintenance.
-JJ
