Brake Booster Line | Ford Explorer Forums
Brake Booster Line
bloxxbmw
Pewaukee Wi
94 XLT,93BMW,00Lex,99Benz
I have a 94 X, and I was wondering where this vac line is to put some Seafoam in it. Also.. is it difficult to disconnect / reconnect?
no tis easy its on the left side of the booster...you can follow it off the intake.
Sorry, still not sure where exactly it is... I am car illiterate! lol.
pop the hood, look at the drivers side...all the way by the hinge for the hood....its about 8 inches in diameter, attatched to it is a container the item looks very similar to this......(its off a bronco but same prinipal)
it easier to just add it down the pvc hose and it will work just the same
Mud Bug..... thank you so much for the post. It was very helpful.
Ryan... so where is the PCV line? Is that the one going directly off the main air intake line?
look on your valve cover there will be a hole with grommet and what looks like a fitting in there (about the size of a silver dollar). there will be a rubber hose that runs off of it to the i think the manifold. i believe its a 3/8 hose. just pull the hose right off and follow the directions, its easier than the line to the brake booster. pm me if you need a picture
Nice picture. Wow, is that a clean engine bay!
its from a late 70's bronco someone restored...i edited the pic in paint to help this guy out...i found it online somewhere but yes its pretty clean.....
