eric27
- August 25, 2010
- northwest ohio
- 93 4.0 xlt
i have a couple questions about the brake booster and the maf. i pulled codes and get a 118 and 412. also sometimes seeing the 159 and the 998 hard fault code.y first question is what affects will be caused by my leaky brake booster? it is leaking inbetween,beneath the studs.
my truck runs okay without my maf connected. but seconds after plugged in it putters and i have erratic rpms....unplugged i get 11mpg plugged in its about 9mpg. i havew e replaced the maf. one o2. cleaned the iac and swapped to check for a difference. new fuel lines, pump and filter. new airfilter. etc. could it just be the other o2. or could my hissing brake booster be setting off codes and messing with my idle. thaks to all who reply
