Brake Light question for a 2000 XLT | Ford Explorer Forums
BigFoxx
MD
2000 Ford Explorer XLT
My 2 lower brake light are out, but the third light still is functional. I have some questions:
1-Do I just replace my brake lights?
2-Is it a wiring/fuse issue?
3-If its a wiring/fuse issue, is there a simple fix? And if so, any instruction/web sites to order the parts?
Thanks in advance everybody!
Why not start by checking/replacing you brake light bulbs? If the bulbs are good, check where the bulb plugs in to for corrosion/poor connection.
It could be brake light bulbs or multifunction switch wiring problem. You can put the tilt column in the all the way up position and see if lights work. The wiring backs out of mf switch connector and causes this problem.
It was the bulbs. Thanks guys!
