Brake lines with Duff lift | Ford Explorer Forums
kaised
Farmington, Maine
1996 Bronco XLT
I never got a conclusive answer last time I asked this question. Can I (is it possible) to use the stock brake lines with the 2.5 lift? I will eventually replace them but do not want to right now.
i am pretty sure it is fine....2.5 isnt that much lift...
It depends on your truck "according to Duff".. but on our 1992 the front wasn't even close.. sitting on level ground the lines were tight.. The rear wasn't so bad, but I replaced all 3 as a set with ones for a 4" lift..
Keep in mind, that even if the look ok on level ground.. think of what happens when you go wheeling.. especially if you remove your sway bars when wheeling..
~Mark
