Brake | Ford Explorer Forums
Brake
mjjd
CA
91 Explorer
Have a 91 and having problems with brake. Replaced pads, bled system. Dash light came on for brake system and rear-anti lock system. Brakes are still mushy. Should I replace the RABS sensor or should i just keep bleeding until everything works?
I had the same prblem with the brakes
I replaced the senor in the rear diff housing
also the rear anti-lock valve.
but the problem turned out to be the sensor in the brake fluid housing had when bad
get that check out befroe replacing the Rabs sensor
