brakes grind when turning | Ford Explorer Forums
panteramatt
south jersey
07 Mountaineer V8
I just replaced both rear pads and the rear passenger rotor in my wifes 2006 mountaineer. Now when i turn left the rotor makes a loud grinding noise.
Check if you have a play in the bearing. I was rubbing the e-brake and it turned out that my rear bearing was shot and the wheel had lots of play (and rotor with it)
