free12travel
- April 16, 2015
- 2001 Sport Trac
Hello
I have a 2001 Sport Trac and I changed the bearings, hub, rotor and pads on both sides as well as the ABS sensors. The passenger side front brakes work as intended, the driver side however makes a grinding noise and the brake pedal shakes / resists when applying the brakes, not the pulsing you would experience when ABS kicks in. After a couple of attempts to use the brakes the ABS light comes on and the brakes work just fine, no grinding noise, no shake or resistance on the brake pedal. I'm desperate to get this fixed and at a loss why they work when ABS light comes on.
