Brakes locked up ! | Ford Explorer Forums
Brakes locked up !
Swanny
Indy, Indiana
'96 Sport 4x4
All four of calipers are locked on to the rotors. Now it won't even move! I have no idea what the problem is. I would appreciate any ideas... Never had any brake problems before. Brake fluid is full.
Not a pro here but I see you havn't had any responces so I figured I would add my .02
How does the fluid look in you MC, is dark and sutty. If so It might be a blocked return port. Also have you done any work on the vehicle lately, if so what and maybe a few more details. Being that all 4 are locked up I would be thinking MC, It would be very unlikely that unlubs slids and the like would cause this, if it was only one wheel I could see it but not being all 4 at the same time. Also was there any indication of problems prior to this happening.
Sorry I can't provide more information but atleast you have a starting point now.
Harry
Did the lock-up occur after driving it? If so you might have air in the lines....as it get's hot it expands causing the brakes to apply a little, which then causes heat to be generated, which then causes the air to expand even more, etc.,etc.. It is a viscious cycle. People burn up (smoke) their brakes by not having the air bled out.
If it is a blocked return port, bleeding the brakes might let the debris get out of the port area and into the line (which isn't great to have debris in there but at least you can move the thing). I have used a turkey baster to suck the old fluid out of the fluid resivoir, refilled with clean new fluid, and then bled each corner until it ran clear. This is the simplest form of "flushing" the brake lines that I can think of. You could disconnect a line near the cylinder, but the brake fluid acts like a paint remover so you'd have to be carful of where the fluid went, AND you would have to bleed all four corners anyways (to make sure no air was in there).
news
I had to end up taking the explorer to a shop. the guy told me it wasnt the brakes. he said the trans. was shot. now i have a guy quoting me a $2900 re build for my trans!! im sick to my stomach. this is my first ford and ive only had it 5 months. the explorer has 68,000 miles on it and all the service records...
Definately get a second opinion. Does the tranny shift into all the gears?
The tranny is being rebuilt as i write this. I dont know what the deal was with the brakes. the tech. told me that the brakes were fine like i was a dumbass. well i took off the front and rear tires and both calipers were locked up completely on the rotors. i dont know much about fords but i dont think thats right.
I would take at least 2 tires off and try to turn the rotor without the engine running. First you should block up the opposite wheels and put it in N. At least you will be able to tell if the stuck part is there or the trans. Also, try to put a feeler gage between the rotor and pads.
You could also try to rock the vehicle by hand back and forth. It will not move at all if the brakes are locked, but if they aren't it should rock a little because of drivetrain tolerances.
Does the engine start OK? Does the trans shift OK? Is the parking brake OK?
All this might be too late after reading over past posts, sorry.
just jack the rear up and try an turn one tire if the other tire spins than it could be the tranny but if it is locked than i would say the brakes
