4shaw5
- October 12, 2009
- Dallas, TX
- 2001 Explorer Sport
I have a 2001 Explorer Sport that I have just replaced the front brake pads on. After re-assembly, when I press the brake pedal, the caliper will not release when the brake pedal is not engaged. From reading on the forum, I am concerned that when I depressed the piston in the caliper, it pushed dirty brake fluid back into the ABS system and possibly clogged a filter of some sort. Also, I did bleed the front brakes. Thanks for you help!
