bluexpy
- September 11, 2007
- Explorer-less
I went this morning to replace the radial arm bushings. First thing I did was to disconnect the driver's side sway bar. That went good.
Then I proceeded to the driver's side lower shock mount. I'd sprayed some PB blaster on the shock mount bolt last night. It was rusted on tight. I couldn't heat it up so I used a breaker bar and tried to get it loose. I managed to snap the bolt off right in the middle! :roll:
I looked at the back at the shock mount, it seems like it is integrated to the radial arm. I can install the nut that's rusted to the disc as it snapped halfway so there is enough thread to tighten it. I know this isn't safe.
I was hoping if it somehow be replaced. I don't think you could remove the radial arm itself, could you? If the shock mount could be replaced, how would one go about doing it?
Here are two pics for the visual freaks.
The broken off bolt.
With it installed, "tight" enough"...
What do to do?
What do to do?
