Broken part in rear drivers side window, what is it? | Ford Explorer Forums
mdisalvo
SoCal
04 Eddie Bauer Explorer
My car got broken into a while back, and I had my rear drivers side window replaced. A few months later the window started getting stuck in place, kind of needing a nudge to move up or down.
Last night I got sick of it and popped off the door panel to inspect and found this plastic piece cracked and not really appearing to do its job properly. I believe this is part of the window regulator, but I wanted to check here and see if anyone knew of any fixes other than replacing the window regulator.
Take a look at the pics below, it's the white piece that looks like it's being pinched together.
You can see in this one it looks like it's cracked and off the track when the window is fully up.
Is this part of the window regulator? Do I have to replace the entire thing?
If it is, is this the right part?
http://www.discountbodyparts.com/ca...62&c2cid=1168febf-bf50-4334-bb5d-b8f078fead4a
I'm going with whole assembly.
That's what I figured...it is the window regulator I will need right?
Yes, it's all one assembly.
