bronco 2 questions | Ford Explorer Forums
bronco 2 questions
lilredbronco2
valley alabama
1986 bronco2
just wondering how yall think my bronco2 will do in the mud its a 1986 detroit lockers front and rear 3 in body lift 31x10.50 mud tracs brand new tires shift kits in trans i believe 410 gears b&m shifter in floor paid 1100 bucks for this lil thing done replaced the flexplate starter coil pack and replacing the fuel pump before this weekend and then hitting the mud just wanna get a idea of what this thing will do from what ive seen on youtube there pretty bad trucks.
100% depends on the mud.
Some mud can devour 44" Super Swampers (in which case a truck with little 31s on it would probably disappear entirely).
If the mud has a bottom your tires can reach to, then you'll probably do fine. The BII is fairly light.
The biggest trouble that my 84 BII has given me while playing in the mud is when the nose hooks a rut that I didn't see, and she tries to swap nose for tail with NO warning. Other than that, I have had her in mud that was so nasty/ deep that she went from red to brown so severely that you couldn't see what color she was anywhere until I opened the door, and even then, NOBODY else wanted to play in the skidderhole that I was having a good time in. Like Junkie said, they are light, and they go like a bulldog after a soup bone if you know how to drive and let the BII so you what it needs to do! It's alot of fun watching the #eeps play on the edge of the mudpit, while you're cutting doughnuts out in the middle and then watching them scatter when you decide that you want out of the mudhole and come out WFO to the edge. Kinda like watchin' roaches in the kitchen scatter when you turn the light on, real sudden like. Never gets old!
