sjr033
- March 19, 2006
- Portage, MI
- 2001 SPORT
Sorry for the crappy picture.... but this is what I mean... Splitting one RCA channel into two inputs for the amp, so the amp is getting the same signal, and outputting the same signal in both channels into the voice coils... Make sense?
You could do this, but it is NOT ideal. Because you would loose any thing that is on the other channel. The way that I would do it is bridge the amp and run the voice coils in series. To do this you wire the "-" of the amp to the "-" of the first VC then run a jumper from the "+" of that VC to the "-" of the second VC and a wire from the "+" of the amp to the "+" of the second VC. The will take the 2- 4ohm vice coils and make the amp "see" 8ohm bridged (4ohm each channel) so your amp will put 350 watts to the 1 channel. Done. Mono signal to the sub at 350watts.
