Ryan92Sport
- February 10, 2009
- Moscow, ID
- '92 Sport
Hi, I have a 92 explorer sport (4.0 OHV obviously) with a 5 speed. It has 171K on it and has always used a little oil (like maybe 0.25 qts or less over a 3K mile oil change interval. It has been 800 miles since my last oil change and it used a quart, and there are no leaks. I did some searching and found that intake bolts can loosen and cause this problem on these engines. I checked the torque on all the lower intake bolts and they were fine. I also checked the PCV and it's not gummed up. Are there any other things that could cause this besides needing a new motor? I am going to do a compression test this weekend but I was wondering if there is anything else I should check while I'm at it. Also, if I do have to buy a reman'd long block, anyone have any suggestions on the best to get? I don't mind spending a little more to know I am getting a motor that will last. Thanks in advance for any help!
Ryan
Ryan
