TarHeel085
And den
- August 22, 2001
- Raleigh, NC
- '99 Sport 4wd
Has anyone ever had a 1354 fail on them? ive searched about my problem symptoms, but they all seem to pertain to the 4405. symptoms im having: grinding in reverse and clunking when in drive, not to mention the clunk that comes along when drive engages and there is a "whirring" in nuetral when the motor is revved up.
Its a 1354 manual shift, the u-joints are all still good, and nothing is loose driveshaft related, the case does have a good amount of miles on it, possibly over 150K, junkyard was unsure of milage and ive at least put 50K on it myself.
Ive read about the whole shift fork thing in transfer cases, but does it apply to the 1354 manual? also while i had it down on the ground yesterday i selected every setting and the all worked as they should ie: 2wd only the rear shaft spun, 4wd they all spun.
any help would be great!!
