bypass compressor pully with shorter serpintine belt | Ford Explorer Forums
heatherleigh190
warner robins, ga
1997 mercury mountaineer
I was wondering if I could bypass the pulley/clutch by just getting a shorter serpintine belt and not loop it around this part. Would my car still run? do I have enough clearance in every spot to do this? would it mess anything up?
thanks
oh, I have a 97 merc mountaineer v8 5.0L
I bypassed the ac compressor using a shorter belt about a year ago, and I'm still running fine. I disconnected the wiring to the compressor and don't put the climate control on A/C.
thank you
Just a quick thanks for the info on the shorter belt. Exactly what I was looking for!! Should have it done by the weekend.
David
I know you can bypass the ac compresser on a 2000 5.0 with a 84in belt works perfect.
